Ford 1910 Glow plug voltage
   / Ford 1910 Glow plug voltage #1
Jeff Gammon
Paragould Arkansas
1910 Ford
What should be the voltage at the glow plug when the key is turned to the preheat position? Right now I am getting about 9.5 volts. I looked at a wiring diagram and believe there is a resistor (the indicator on the dash) in the circuit that would cut the voltage but I am not sure by how much. It seems to take quite a bit of time for the glow plugs to heat up enough for the little tractor to start.
Thanks,'
Jeff
   / Ford 1910 Glow plug voltage #2
There will be a voltage drop as the plugs draw heavy current, that's normal.
The dash resistor is most likely your glow indicator. It will glow when ready to start.
On a tired battery you probably won't read 12 volts after a heat cycle or 2.
A good battery will still read 12 V even after a couple of heat cycles.
Also there are 2 types of glow plugs, fast heat and slow for want of better description. Theory being that the fast glow units will burn out faster and more often than the slo types.
My guess is that you have no problem. My 3 cyl engine often wants 2-3 glow cycles on colder days even when plugged in for an hour or 2.
Just looking at the wire sizes leading to the glow plugs are your indicator as to current draw.
Make sure that all contacts and grounds are clean and tight.
   / Ford 1910 Glow plug voltage #3
Thanks,'
Jeff
How long are holding the key to the glow plugs, in seconds?
What is the outside temperature when you are having delayed starting?
I give my 1700 20 seconds when temp is above 50 and 30 seconds when temp is 30 or lower.
I gave it about 40 seconds the other morning when the temp was 38 F. I had to do it 2 times before it would start. I hadn't checked the glow plugs yet to determine if they are all good. I have never had a diesel, but assume if I had 1 bad out of 3 it might cause a problem
   / Ford 1910 Glow plug voltage #5
That is more than enough time to get things heated up. Next question, where do you have the throttle set when heating the plugs? What works for me is to have throttle closed for the first 30 seconds and then open it to the running position (about 1500 rpm to start) for the next 10. Then crank with the throttle in that position. Other posters may do it different.
Sometimes a bad ign switch can cause a slow starting problem. How many hours on your tractor?
1800 hours on my tractor. Why does it make a difference what position the throttle is in while heating the glow plugs? I never thought of that making any difference till you get ready to start it, but I am new to diesels
   / Ford 1910 Glow plug voltage #7
+1! A good battery and tight connections are the keys to a good glow lamp cycle.
2018 John Deere XUV560E 4x4 Gator Utility Cart (A46684)
2018 John Deere...
12-16.5 Forerunner SKS4 Tires (A49251)
12-16.5 Forerunner...
Large Grain Bin (A49251)
Large Grain Bin...
Fork Lift Forks (pair) (A49251)
Fork Lift Forks...
Ingersol Rand Air Compressor (A49251)
Ingersol Rand Air...
New Holland 790 Silage Harvestor (A49251)
New Holland 790...
