Ford 1900
   / Ford 1900 #1
Josh0430
Ford 1900
I am getting ready to change out the hydraulic filter in my tractor. I have noticed that the fluid is milky white which i know means water has gotten into the system. What i would like to ask is, can i drain the fluid and then pour diesel fuel in to clean out the trans area before putting all new fluid in? If not then how to clean the inside of trans area.
   / Ford 1900 #2
I don’t know how much fluid your trans holds, but might be best to buy some economy priced fluid and run it a little while, then drain it. See if it still looks milky, if yes, do it again until you get clean oil, then put the good stuff in. Little more expensive, but you can run the fluid through all the internals that way whereas diesel would be more of a flush with tractor standing still.
Ive seen it where diesel has been used, but I dont think it is as thorough as a fill & drain with trans fluid.
17801 (A51694)
17801 (A51694)
2011 DODGE RAM 2500 (A52472)
2011 DODGE RAM...
2023 Diamond Cargo Trailer (A50324)
2023 Diamond Cargo...
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2016 Ford Focus Sedan (A50324)
2016 Ford Focus...
