ford 1900 with771 loader lift speed adj.
   / ford 1900 with771 loader lift speed adj. #1
honkerone
Hello, I just purchased a 1900 ford with 771 loader, it seems to me that the lift speed of loader and bucket tilt speed is very slow, is there a hyd flow adj.? or do I need to look for other issues? It has 2000 hrs and does not look to be mistreated. Thanks I appreciate any iformantion I can get on this. Joe
   / ford 1900 with771 loader lift speed adj. #2
When was the last time the hydraulic filter was changed? Was the right kind of hydraulic fluid put in it? Must meet Ford 134 specs. Have the hydraulic pump pressure tested. You'll need a manual and pressure guage. Is spool valve on the pressure releif valve/diverter valve in the correct position? Get a manual. Send me a personal e-mail addrress to junk93619@gmail.com and I can send you a ton of diagrams that can't be attached in TBN mail.
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
JMR Attachments Tree Boom (A50121)
JMR Attachments...
