Ford 1900 with 771 loader wont raise.
   / Ford 1900 with 771 loader wont raise. #1
tractorgirl93
Ct
Ford 350B, Ford 1900 w771 loader
I just fixed the lever assembly for the loader. The bucket will only go as high as the crossbar and the bucket wont tilt. I checked the fluid and its okay. Do I have to bleed it?
   / Ford 1900 with 771 loader wont raise. #2
most hyds self bleed.
On a loader that won't raise all the way, but will raise some..., check fluid .. make sure you are not low.
Thanks Soundguy for your reply. I did put more fluid in. What is the fill point? I lost my book and ordered another but it hasnt come yet. There is a notch on the stick and the fluid is up to there.
   / Ford 1900 with 771 loader wont raise. #4
not familiar with a 1900, it's a older cousin to the 1920 I had.. which, again.. has been about 10ys ago.
Ok, thanks SG
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
