Ford 1900 with 771 loader question
   / Ford 1900 with 771 loader question #1
CACameron
Ford 1900
Hello,
I have an 81-82 Ford 1900 that is new to me as are tractors. I have been working through doing all the scheduled maintenance and having fun learning. One thing I noticed is I can lift the front with the loader if I rotate the bucket, but if I raise the bucket a try using the loader cylinders it won't lift it back up. I also noticed while trying to do this the 3 pt wants to go down. I have tried putting the 3pt up and down as I read it needs to be in neutral?? to no effect. It does have a slight leak in the left cylinder as well, could this be the issue? Or are these just SA cylinders?
Thanks,
Chris
   / Ford 1900 with 771 loader question #2
First, your Ford was made by Shibaru. Ford rebranded many small models as their tractor.
TractorData.com Ford 19 tractor information
Spec's on your loader:
TractorData.com Ford 19 tractor attachments information
If your hydraulic cylinders have two hoses on each one., they are double acting. It would be unusual for them not to be double acting n a factory made loader.
It is not unusual for a loader to be able to lift the front end using the bucket whereas it cannot do so using the loader arms. It is just a matter of geometry of the cylinders and where they apply forces.
Not certain why the 3 pt is moving when the loader is.
Dave M7040
Thanks, Dave!
I guess I won't worry about it then. I thought it may be a symptom of a larger issue.
   / Ford 1900 with 771 loader question #4
my 1979 ford 1900 will not lift the front with the loader arms but will easily do it with the bucket curl. Its always been that way, like mentioned above its just not a strong angle for the lift arms. not sure about 3 point.
2015 Manitou MLT840-115 PS 4WD Telehandler (A50657)
2015 Manitou...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
2012 KENWORTH T800(INOPERABLE) (A50854)
2012 KENWORTH...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2019 TAEKUCHI TL8 SKID STEER (A51242)
2019 TAEKUCHI TL8...
