ford 1900 speed shifter stuck in 4th
   / ford 1900 speed shifter stuck in 4th #1
dads501
cmch NJ
ford 1900
I have a Ford 1900.I put it in high gear (4th) and it will not come out. I stopped the tractor at idle, shut it off , put it in gear, rolled it alittle back and forth, apllied force ( not too much) pulled the shifter up and tried, pushed the shifter down, will not come out. It will go in 1,2,3,R, but in high gear.
Any help or sugestions before I pull the top plate off?
Thank you
   / ford 1900 speed shifter stuck in 4th #2
I think you have a detent ball that is stuck. The balls get worn and some times get wedged. You will find the detent balls and springs under the bolts near the shifter.These are not the bolts that hold the cover on. If you search posts by JC in the newholand forum he has some detailed pics.
Bill
Well that was an easy fix. Thank you very much. Just went outside and removed the 2 bolts that hold the spring down and it released the shifter. Now its back to work. Thanks again!
   / ford 1900 speed shifter stuck in 4th #4
did you remove the cover also??
I have the same problem with mt 1900
5' X 20' 3/8" THICK STEEL PLATE (2) PIECES (A51244)
5' X 20' 3/8"...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52141)
2015 INTERNATIONAL...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
UNUSED AGT MX12RX EXCAVATOR (A51243)
UNUSED AGT MX12RX...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
