mellowrose
- Joined
- Oct 31, 2012
- Messages
- 31
- Location
- hallettsville tx
- Tractor
- ford 1900 kubota b8200 ford 1700 all 4 wheel drive
ok, my first post and i already want to know something. i joined this forum because most everybody here seems know what they are talking about. bought this tractor and everything seemed to work ok. so we went to work. shredded weeds and small trees( about an inch wide ) with good results. moved a bunch of brush piles no problem. put maybe 50 or 60 hours on it, all the time watching the gauges and listening for weird noises. got the tractor for a reasonably price i thought. started noticing the pto would not engage without grinding and then would not engage without turning the tractor off. after a while the clutch started slipping. we are now seeing a trend that cannot be ignored. so we decide to change the clutch, how hard can that be, right?? after getting manuals togeather and studing all related post here and a few weeks of maybe i should have someone who knows what they are doing fix it, we get all related parts from ford and some others that might as well be changed out while i am at it, the work starts. all goes well until time to put the motor with new clutch back into the clutch housing. would go part way, then most of the way and no further. did not have an alighnment tool, so i took the clutch housing back off and used the drive shaft to align stuff and tried again. eventually it went togeather by wiggling, turning the flywheel, wiggling, turning the flywheel until that last little bit when it goes into the pilot bearing. wow, what a good feeling. all the moving and turning was done without forcing it, so when everything finally lined up it slid into place. put everything else togeather without much problem. so now its time to start it up. after bleeding fuel lines, runs as before. now comes the problem. with the clutch in, smoke comes out of the inspection hole for the clutch. it only smokes when clutch in pushed in and held for a few seconds. let the clutch out and it stops smoking. also with the clutch in the motor bogs down some. the clutch is turning and not making any noise. now i only did this a few times and then stopped. the last time i did check the pto and it went in without grinding( motor running ). did not check any gears as i did not want to push my luck. thats it, seems to me that if it finally went togeather kind of by itself, it should be right. kind of afraid to go any further and hope you'all say, well its just kind of getting rid of any cleaners or dirt or something i did not get clean enough. will take it back apart if i have to, but not sure what i could have done wrong. any ideas would sure be welcome, as i think i am not sure what to do now. i do apologize for writing a small book here and look forward to hearing from some of you. thanks
