Ford 1900 3pt not lifting MORE ??????
   / Ford 1900 3pt not lifting MORE ?????? #1
Kenny G
Medford, Wi
400G JD,E120 CAT,5660 AGCO,1100,1200,1300.1500,1700,1900 Ford
I hope I have this in the right forum.I know this subject has been talked to death. I still have a few questions. I have a 1900 with factory remote valve. I have no oil or pressure at right side service port. I do have oil at relief valve. When I raise & lower remote valve lever I hear & see hoses jump. It sounds like interal control valve or seal on lift cyl. If it was a bad or broken seal wouldn't it make the 3pt try to move a little. There is valve or plug on the left side of the head what is that for? There is also a 1/8" plug on the front of the control valve what is that for? I have new oil & clean screen.Can interal control valve be worked on when lift cyl is removed Thanks
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
3 pt Finishing Mower (A50514)
3 pt Finishing...
Rain-Flo Vegetable Transplanter (A50120)
Rain-Flo Vegetable...
1275 (A50490)
1275 (A50490)
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
Agco Hesston 4590 Square Baler (A50515)
Agco Hesston 4590...
