Ford 1720 Hard starting runs rough!
   / Ford 1720 Hard starting runs rough! #1
chipmaker
Central Alabama
1720 Ford
My 1720 started to run very rough, and was hard to start. I changed the fuel filter, and the problem persisted. It would trun over and never fire up, someitme it would fire up, but would idle and run rough. I sort of leaned towards clogged injector(s) or injection pump problems. Cleaned and bled injectors, still had the problem. Got prepared to swallow the pride and spend the bucks n a new injeciton pump or take the original and have it repaired / rebuilt. Out of a whim, i checked power to the fuel injection pumps solenoid when I tried cranking it, and it turned out to be intermittent. It turned out to be a defective ignition switch. Sometimes it worked fine, other times it did not, but the problems sure pointed to fuel problems to begin with. $92.00 later for a new ignition switch it runs like a champ again. By design its impossible to keep water out of this switch, unless you keep it stored under a shed all the time. Don't think I will ever buy an O.E.M. switch, and will go generic if it ever happens again.
   / Ford 1720 Hard starting runs rough! #2
92.00 for a key switch? your dealer took big time advantage of you! /w3tcompact/icons/sad.gif
2025 CFG Industrial PD750-PZ Post Driver Skid Steer Attachment (A49462)
2025 CFG...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
Pit Boss Lexington Wood Pellet Grill Smoker (A49462)
Pit Boss Lexington...
