Ford 1715 Sticks in Gear
   / Ford 1715 Sticks in Gear #1
Phil2004
Ford 1715
I have a 94 Ford 1715 4wd that has been getting stuck in gear. It started grinding more than usual when shifting into second and reverse, then one day while pushing a brush pile it got jammed in gear and wouldn’t come out. When I removed the top trans cover it came right out.
Its done it a few more times and comes right out when I pop off the cover. Gears and everything look ok. The ball is kind of worn on the bottom of the shifter but I can’t see how that would cause it to jam.
Any insight would be appreciated.
   / Ford 1715 Sticks in Gear #2
Is the oil level where it’s supposed to be ?
My 8N started doing stuff like that and when I checked the oil it was way low so I filled it to the proper level and the problems disappeared, that was a few years ago and no problems since.
Yes the oil level is spot on. That was the very first thing I checked…
So after replacing the shift lever the problem seems to have resolved itself.
I took the lid off and ran through the gears with the old shifter that had a pretty worn ball.
1st and 3rd is engaged with the top shift lever and 2nd and R is engaged by the bottom. With the ball being worn, when I went from one shift rod to the other (from 1st or 3rd to 2nd or R, or vise versa) it wasn’t disengaging all the way then the rods would jam when I tried to select a gear.
The new lever seems to have solved the problem.
   / Ford 1715 Sticks in Gear #5
I had a 1949 Farmall Cub with exact same problem. The little ball on the end of the shift lever was worn off. So sometimes it did not align/engage the u shaped fork to move the transmission in and out of the gears. Replacing the shift lever fixed the problem. Glad yours was a simple fix.
   / Ford 1715 Sticks in Gear #6
I am having the same issue. I've discovered I need to replace the shift lever. Where did you find a replacement? Thanks.
Payment Terms (MUST READ) (A50775)
Payment Terms...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2003 Mercedes-Benz CLK-320 Convertible (A50324)
2003 Mercedes-Benz...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
