3 Horse Ranch
Veteran Member
- Joined
- Aug 18, 2017
- Messages
- 1,193
- Location
- Tonasket, WA
- Tractor
- NH B50H Cab, Ford 1715, Poulan Pro 46
The adjustable side link on my tractor is worn out. The threads on bottom and cemter sections are barely holding and it often slips a little when I hit a bump. I've looked at replacing the whole thing but the cost was close to $300, which is highway robbery for such a simple part. (It's basically a small top link)
I purchased what I thought was a replacement for $35 but the ball hole is 3/4 but my tractor has. 7/8s pin. The two solutions I can think of are pressing out the 7/8s pin and installing a 3/4 pin or finding a shop that will cut the ball end off both and weld the 7/8s ball end on to the replacement link. Pressing out the pin will require removing the lifting arm from the splins and finding a shop to press the pin out. I am leaning towards the cut and weld solution.
My absolute first choice would be to buy a replacement that fits, either aftermarket or used at a reasonable price. I sire would like to find a source if anyone knows of one. Or if anyone jas a better solution, I'd lile to hear that also.
