Ford 1715 4WD Drop Box Oil Capacity!?
   / Ford 1715 4WD Drop Box Oil Capacity!? #1
Phil2004
Ford 1715
I am looking to replace the oil in my 4WD gearboxes, but the manual doesn’t list an oil type or capacity.
The drain plug is at the bottom of course but the fill hole is clear in top of the case and I know it doesn’t take that much. For fluid I just plan on using regular old gear oil, although I’m told I can use something thinner like 134?
Any info is much appreciated!
   / Ford 1715 4WD Drop Box Oil Capacity!? #2
   / Ford 1715 4WD Drop Box Oil Capacity!? #3
Hope this helps...?! You're welcome....
Thanks Robin. The hubs are separate from the front axle so it doesn’t really specify how much to put where. I just filled the hubs up to the top plugs and the axle up to the dipstick. Seems to be alright
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2015 FORD E350 16FT BOX TRUCK (A52576)
2015 FORD E350...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
