Long story short, thought my fuel intake at the injection pump was leaking because the fitting was loose, come to find out it was cracked in the threads, went to tighten it us totally broke it off. re routed my fuel through the bleeder hole and plugged the original one. Teed off the fuel like to make a bleeder. I pulled the pump for this. I marked the timing before removing. Got everything back together and running and noticed more smoke than usual. Looks like air intrusion smoke or the timing is just a bit off. Can you turn these pumps to advance and ****** the timing? I looked in the manual that i have and didn't see anything about this but the pump slots seem to be cut for this reason. If so does anyone know which was to turn the pump to advance the timing?
