Tires Ford 1710 rear wheel centers
   / Ford 1710 rear wheel centers #1
SuperChief
Ford 1710, 8N, 600
I currently have Turf tires and want to change to AG. Are there any aftermarket/compatible wheel centers that can be re-drilled to put on the 1710 rear wheel ?
   / Ford 1710 rear wheel centers #2
I think the standard AG wheel size if 10 x 24, for a 11.2 x 24 R1 AG tire if it's the same as a 1715. Not sure of your shop capabilities, but if you really get stuck you could order the bare outer rims for about $130 each and have centers fabricated for them .... pretty much flat steel 3/8" plate square with the corners turned up, with hub holes and lug holes drilled .... I'd bet a good steel shop would do them for about $150 a piece if you made the drawings. I know that's a reach, just throwing it out there if you can't find anything.
I am more interested as to what centers on any make/model would 'fit' in the dimensions of the tractor, then have those centers re-drilled to match the brake hub and then get the outer rim to match the modified center. Appreciate your input and may be helpful if I don't get it right.
   / Ford 1710 rear wheel centers #4
A generic 4 loop 24 inch rim will fit the OEM center. I am not aware of any centers (discs) from other brands that would fit the pilot diameter or bolt circle of the 1710s axle flange. There may be one, but I am not aware of it.
   / Ford 1710 rear wheel centers #5
Any 10 x 24 Rim with a 11.2 x 24 tire will fit the dimension of the tractor ... if you mean physically fit under the fender, and be the right height. Hub centerlline probably isn't a big concern as most are similar, and the 1710 can reverse the wheels for different offsets so there is a wide range there.
It's probably going to be a bit more complicated than buying a complete wheel and re-drilling. Most 10 x 24 rims are two piece, you'd need the rim and the center section, the rims are easy enough to find, but the center sections are not. If you can find a center section close enough to use it will likely need the bolt pattern re-drilled and the center hole resized ... maybe larger, maybe smaller. The 17 series Fords used a smaller bolt patter and center hole than most and one piece welded wheels. If money is no object you can probably still order complete wheels from New Holland but last I checked they were about $600 each.
If it's four wheel drive ... keep in mind you have to put the proper size AG fronts on also.
I went through this a while ago, searched for months for a suitable wheel to use. Turned out my only option was used wheels, or buy a new outer rim and weld to my AG center section.
Might want to check the for sale section .... always people switching back and forth between AG and Turf ... I know you can use the same wheels as a 1715 also.
2016 Ford F-550 4x4 Bucket Truck, VIN # 1FDUF5HT8GEB70191 (A51572)
2016 Ford F-550...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
2018 JOHN DEERE 5075GN LOT NUMBER 100 (A53084)
2018 JOHN DEERE...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
