Syncro
Platinum Member
The PTO on my 1710 does not disconnect when the clutch is depressed. I got the tractor used and don't know if it has a dual action clutch, but no matter the adjustments I can not get the PTO to stop turning except to release the engagement lever. The transmission shifts fine, even from forward to reverse without grinding while the PTO turns merily along. There is no 'jumping' when changing gears and the clutch is smooth and positive. Any ideas?
My thoughts are that it has a dual action clutch and maybe the PTO clutch plates are forzen together. I hooked up a bushog and ran it vigorously cutting 4 acres thinking maybe that might free it up, but no dice. If that is indeed the case, any solution short of spliting the tractor?
On a side note, does anybody know if the oil reservoir on the front diff are common with the finaL gear reduction cases on the front wheels?
