Ford 1710 leaking antifreeze and knocking
   / Ford 1710 leaking antifreeze and knocking #1
Ford bedford
Crestwood
Ford 1710
I have a ford 1710 that over heated and is leaking antifreeze behind the fuel injection pump. Is there a freeze out plug behind the pump? It is also knocking. Changed the oil and filter and found no metal, antifreeze , etc.. in the oil. No oil leaking anywhere, just the antifreeze. Could the knocking be a valve, piston, etc..?
   / Ford 1710 leaking antifreeze and knocking #2
Probably blown head gasket.
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
