Recently while running the rotary cutter on my 1710 the 3pt dropped and would not lift. I noticed the hydraulic fluid was milky so I drained and replaced fluid and filter. 3pt still wouldn't lift. I then pulled the lift cylinder and the seal was brittle and broken into little pieces. I replaced the seal and still have no lift. This has me puzzled because the FEL works fine. I am assuming there is a blockage somewhere but I'm not sure where to look. If I loosen the fitting in the 1st pic that I believe sends UTF to the 3pt fluid comes out but doesn't seem to be a great amount of pressure. Any ideas?
