LS XR4046HC, Ariens 60" max zoom zero-turn- Cub Cadet 1050 Rider
quick attach is a method to install and remove the bucket that is attached with levers into a channel. I don't know the setup for your particular tractor but you can purchase weld on plates to make a fixed attachment into a QA setup. if you are purchasing a new bucket anyway this is a good way to go. check out titan attachments, they sell the plates and also buckets. many others do also. with this type of setup you would be able to add forklift forks, a grapple, a rock rake, etc. making the FEL a lot more versatile. Donald Fluney Welding : Quick Attach Systems
