Ford 1700 tractor
   / Ford 1700 tractor #1
walton
Milledgeville, Georgia
Ford 1700/kubota 2230
On my ford 1700 there is a L shaped lever below the seat on the right side. What is the purpose of this lever? Thanks for all the replies on the pto.
   / Ford 1700 tractor #2
Is it the lever attached to the seat that allows the seat to slide back and front? If it is it may be rusted and not function. Or is it the differential lock lever (pedal) close to the floor board? Or something else. Can you post a picture.
Andy
   / Ford 1700 tractor #3
I'm not familiar with a ford 1700 but it sounds like it could be draft control? Soundguy would know for sure.
mark
   / Ford 1700 tractor
It is pedal located close to the floor. It is not the seat control. Sorry I do not know how to post pictures.
   / Ford 1700 tractor #6
walton said:
What does the differential lock do?
Locks the two rear wheels so the turn together. No lock means one wheel can lose traction and the other can be still.
Bob
   / Ford 1700 tractor
Do you have to stop the tractor to use the differential lock or can you engage the lock while the tractor is moving? Thanks
   / Ford 1700 tractor #8
You just step on it when the tires are spinning and it will lock them so that you get equal power to both wheels. Be sure you get off of it when you are moving again and don't try to turn while they are locked. It's not good for the rear end!
   / Ford 1700 tractor #9
Mike
Usually when I engage the differential lock I am in very sloppy conditions. I have no problem turning either my 2120 or TN75. On the TN, the differential lock , locks both front and rear axles.
Andy
   / Ford 1700 tractor #10
You MUST not have one rear tire spinning faster than the other when you step on your diff lock pedal. If you do there is a very good chance you will shear off the pins. This style of diff lock is a jaw type, not a disc type. It can be engaged when moving as long as you are traveling in a straight line with no wheel slippage. One wheel spinning faster than the other + stepping on your differential lock = broken parts.
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
2012 PETERBILT 365(INOPERABLE) (A52472)
2012 PETERBILT...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2011 GLOBAL 130BBL VAC TRAILER (A52472)
2011 GLOBAL 130BBL...
BROWN MPT-30 LOT NUMBER 67 (A53084)
BROWN MPT-30 LOT...
