Ford 1700 stuck clutch
   / Ford 1700 stuck clutch #1
jones6780
Lizella, Ga.
Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn
Well I had my first experience with a stuck clutch. I had my tractor over at my mothers doing a little work and I had to leave it outside uncovered. It rained and was a week later before I got back to finish. When I started it up the clutch was stuck and would not release. I had a middle buster on and I blocked the clutch down and used the middle buster to put a load on it. Made several passes with no luck. Came back several days later and tried again. I moved to an area with tree roots and used the lift to regulate how much weight to pull. I tried to keep the tires spinning but not enough to spin and get stuck. Took several passes but it finally broke loose.
Guess I might need to block the clutch from now on.
Russell
   / Ford 1700 stuck clutch #2
That same thing has happened to my dad in the past . He ended up having to have the tractor split as we couldn't get it un stuck.
   / Ford 1700 stuck clutch #3
Russell
Hey Russell,
I'm afraid blocking is the only sure thing to do. I have a piece of high $$$ 2x4 that I use winter or summer and always block. Knock on wood, so far I have never had a stuck clutch.
JC,
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2023 Ace Cargo 6x12 Food Trailer (A51572)
2023 Ace Cargo...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
2022 John Deere 8R 310 MFWD Tractor (A53342)
2022 John Deere 8R...
