Ford 1700 Hydraulic problems
   / Ford 1700 Hydraulic problems #1
wonl2
Taylors
Ford 1700
Hello Forum, I bought a Ford 1700 tractor with 550 hours on the meter. It has been sitting for around 10 years per sellers family. The engine started up fairly easy and runs great. The problem I have is that the hydraulics work maybe for the first 5 minutes then stops. The front end loader and 3 point stops working. I still can drive it though. I drained the hydraulic fluid and cleaned the screen. The oil was a "milky white" and the screen needed to be cleaned. New oil was placed into the reservoir and the hydraulic system seemed to work great. My excitement came crashing down about tem minutes later when the same problem came back. I bought a 5000 psi gauge and installed it in the port that's next to the knob that controls the 3pt speed. There was no pressure and only a very small amount of fluid trickled out of the hole when the plug was removed (even with the engine running). I thought that the screen was dirty from all the years of sitting so I drained the fluid and cleaned the screen again. The screen was a little dirty and the fluid was still slightly milky. New oil was added to proper capacity. Now the hydraulics don't even work at all when the tractor is started. Sorry for the long story but I wanted all details described. Thanks for helping!
   / Ford 1700 Hydraulic problems #2
I'm not sure about your tractor but mine has a filter and a screen. Filter stopped up?????
I don't know if it has a filter. Gonna look into it. Thanks
   / Ford 1700 Hydraulic problems #4
No hydraulic filter on the 1700 only a metal screen. My old 1700 when the screen would clog would start to jerk and move slow. Knew it was time to clean it. The tractor was not tall enough to put a5 gallon bucket under it to drain the fluid. I cut a little off two buckets. I have a 1920 now. Really like the shuttle shift on the 1920 compared to the one on the 1700.
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2000 Ford Ranger Pickup Truck, VIN # 1FTYR10V0YTA06580 (A51572)
2000 Ford Ranger...
2001 John Deere M665 (A50120)
2001 John Deere...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
