Ford 1700 head bolts question
   / Ford 1700 head bolts question #1
Joetheroux426
Ford 1700
I am replacing the head gasket on my ford 1700 2 cly. diesel and need to know the pattern to tighten the head bolts and torque.
   / Ford 1700 head bolts question #2
The actual torque value I cannot help you with...
But always torque heads in a criss-cross pattern. Are you familar with that? It's difficult to describe on a post, so I made a quick sketch (just a start, but I'm sure you can follow through from there). It's just a sketch, but gives you the intent of the criss-cross pattern. It would probably be better to work from the center out each way, actually (rather from the corners). I've seen both methods used.
It's also important to do a progressive torque. This means you'll torque three times. The first would be at 30-35 percent of the (finish) torque value, the 2nd would be at 60-65% of that finish torque value....the third would be at the finish torque value.
The intent is to pull the head down evenly which is what the criss-cross pattern and progressive torquing provides.
Sometimes heads require retorquing after a specified number of hours too. Also, if you do find a manual and it differs from my sketches, always go with the manual!
  • Criss-Cross Pattern.pdf
  • Criss-Cross from Center.pdf
   / Ford 1700 head bolts question #3
The torque is 107 - 110 ftlbs. The manual doesn't give a torque sequence. I always start in the center and go in a circular pattern working my way out.
Bill
Thanks for the replies, I ordered a service manual, if the sequence is not in there I will work my way out from the center.
   / Ford 1700 head bolts question #5
Thanks for the posts. Can anyone tell me what sealant to use on the head gasket and valve cover gasket? I have a blown head gasket (pressure build in radiator similar to another post in these forums). Also need a good quality source for the gaskets.
378746 (A51573)
378746 (A51573)
2020 KENWORTH W900L DAY CAB (A52472)
2020 KENWORTH...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
