Derrick Farm Pride
Hello I am working on a ford 1620 hydro and it came in with a problem of you would run it for an hr or so and you would loose all hydraulics ( loader and hydro) so you shut it off and let it cool down and it would work again for a short time (30mins to 2hrs). I done a pressure check at the loader valve and it was in the range of 1200psi and when I would loose all its power the was no pressure at the loader valve. So I put a new hydraulic pump on it along with all new filters and it brought the pressure up to 1500 on the valve but still has the issue of loosing all power. So I drained all the hydraulic fluid out of it and dropped the mid mount pto so I could look in the case with a camera and still did not find anything. Took the suction filter off and housing and used the cam to check the internal tube out. No restrictions there. So that is where im at and have no idea where to go now. Hope someone has had this issue and can lead me in the right direction. Thanks
