FORD 1520
   / FORD 1520 #1
emorris
tennessee
newholland tc30
I AM LOOKING FOR A HOOD FOR A FORD 1520. I RECENTLY BOUGHT A USED 1520 2WD FROM THE CITY FOR $700. IT HAD WELL OVER 2000 HRS AND RAN OK. I KNEW WHEN I BOUGHT IT I WOULD HAVE TO PUT A CLUTCH IN IT AND THAT THE FRONT AXLE PVIOT PIN AND BUSHING WERE WORN OUT AS WELL AS THE FRONT AXLE NEEDED SOME WELDING, BUT FOR 700 I COULDNT PASS IT UP. I HAVE ALREADY PUT THE CLUTCH IT IT AND LUCKLY IT WAS JUST THE SINGLE CLUTCH DISC AND NOT THE COSTLY DOUBLE CLUTCH. I HAVE CHECKED WITH SEVERAL SALVAGE YARDS BUT COULD NOT FIND ONE. THE HOOD DOES NOT HAVE TO BE IN PERFECT CONDITION SINCE ALOT OF THE SHEET METAL LOOKS ROUGH. I AM UNWILLING TO PAY FOR A NEW ON FROM NEWHOLLAND/FORD. I HAVENT DECIDED IF I AM GOING TO KEEP IT YET, BUT IT HAS A WIDER STANCE THAN MY TC30 AND WOULD BE MORE STABLE WHEN BUSHHOGGING ON HILLS.
   / FORD 1520 #2
I will assume this is an older 1520 from 1990's. you may want to remove it and see what a body shop wants to repair it and paint it. At a $700.00 buy; if all items are in good/average condition , you got a good deal. I bet quite a few other model hoods will fit also!
   / FORD 1520 #3
Google "compact tractor salvage yards" you should get quite a few hits.
Bill
   / FORD 1520
Yes it is the older one not the newer 1520
   / FORD 1520 #5
Have you checked Long Lane Tractor in Pennsylvania? Ken has an early 90s 1620 HST that he's parting out. I bought some parts for it for my early 90s 1520. I think most parts are interchangeable between these two models. Ken can verify that for each part.
If I remember correctly, the 1620 had a good hood on it when I was there about a month ago.
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
Husky GHM105890 Cement Mixer (A49461)
Husky GHM105890...
