Ford 1520 brake discs
   / Ford 1520 brake discs #1
dufferjames
I have a small shop manual, but from the picture or info provided I can't determine the number of brake discs per side. I ordered two at cost of $130.00 thinking I could replace both sides, however I noticed an extra brakes disc on the left side. Now I wondering if I missed replacing one on the right side (I only replaced one) At a price of $50+ each it looks like this may end up being an expensive job. Are their two on each side?
   / Ford 1520 brake discs #2
Go to the New Holland site and look up the parts listing. It will show a much better picture. I am finishing up a full set of shoes on a Ford 2110 today. Go them relined in Medford , Oregon for $180 all four. I live in Fresno county, CA. The XX20 size tractor should be oil cooled disc, which likely calls for draining the trans. I have a 1920 and hpope I don't have to do a brake job on it.
   / Ford 1520 brake discs #3
Just looked up my 1920 Parts manual. 1920 has 3 disc per side. 1520 may not be the same. NH site is best answer.
Thanks, I will find that NH and check for the number, if it is 3 per side that means $300.00+ to replace them if you use Madison Tractor. Tomorrow I will be near a NH dealer I will also ask them what is the scoop. If it is three, you would think they would sell them in a set of 3?? Yes they are wet discs and you have to drain the hydrtaulic oil (about 5 gal.).
I found the answer, there are two per each side. Seldom ever need replaced according to the local NH dealer. I thought the new ones did not appear any better than the ones were there.
Thanks for those who provided info.
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
Arksen Rollable Fuel Cell (A51573)
Arksen Rollable...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
New/Unused CFG Industrial QK16R Mini Excavator (A51573)
New/Unused CFG...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
