I spent yesterday afternoon hauling dirt from the downhill corner of a field to a spot about 1200 feet away, a bucket at a time. I also had an old Ford disc mounted on the rear, and as I passed selected areas, I was hitting those areas with the disc.
Near the end of the afternoon, I had to do some slight regrading of an area I had disced up, elsewhere, and move buckets of top soil 50 to 100 feet to change the distribution of the dirt. At this point the hydraulics became jerky.
The loader was jerky and slow to cycle, and the lift for the disc was jerky and slow. I shutdown the tractor, blew the dust off of it, and did an inspection.
The hydraulic fluid was just slightly above the fill mark, which makes sense, because the last time I filled it the temps were cooler, and I filled to the top of the mark. The fluid was clear and had no glint to it. I put some on a clean paper towel so see if there was any thing I could see as it spread. Nothing. Looked for leaks, none found.
The hydraulic filter was replaced early this year, about 25 operating hours earlier. The flexible hose on the inlet side of the hydraulic pump appeared to be intact and firmly attached. (Has anyone found a second source for this hose...it costs about $40 from the dealer!)
I started up the tractor, cycled the hydraulics on the loader and the 3pt hitch, and everything worked just fine. Now I am really perplexed.
Any ideas or suggestions?
