Ford 1510 alternator wiring
   / Ford 1510 alternator wiring #1
nate1616
Milton, fl
1510 ford
I have a 1510 ford tractor that runs good. I got a new alternator and voltage regulator for it, the problem is I have no wiring for either and don't know how to wire it up. All I'm wanting to do is charge the battery. The alternator has 3 Male prongs on the back plus the battery post. The voltage regulator has 6 Male prongs on it. Anyone have any idea how to wire this thing up to get my battery charging? Thanks for any help.
   / Ford 1510 alternator wiring #3
I recently ran into this very problem on a 1710. If you can verify that your tractor has a Hitachi alternator and not a Denso, then this diagram should be a match. The color coding is a bit vague, but the circuits did match up, and in my case I was able to trace down the missing signals. I did have to remove the fuel tank to access the regulator wiring.
/partstore.agriculture.newholland.com/us/ValleyImplementNL/parts-search.html?csid=67486e42e2e1e431254eb57264a10047&sl=EN&currency=#epc::mr54189ar676531
2016 Mercedes-Benz C-Class Sedan (A46684)
2016 Mercedes-Benz...
2017 FORD E350 16FT BOX TRUCK (A45678)
2017 FORD E350...
1997 Haulmark Transport DXL / KD7X16WT2 Enclosed Trailer (A46683)
1997 Haulmark...
2001 Ford F-350 Crew Cab Flatbed Truck (A46683)
2001 Ford F-350...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2016 Ford F-150...
11.2x38 Tractor Tire (A49251)
11.2x38 Tractor...
