Ford 1310 Lube Question
   / Ford 1310 Lube Question #1
snoopydog101
Can someone tell me what type and how much lubricant I need for the Manual Steering Box on my Ford 1310 tractor? Local dealer is closed today or I'd just call them. My manual does not have the info on the page that the description says it is on and I've not been able to find it anywhere in the book.
   / Ford 1310 Lube Question #2
I'm not familiar with that machine.. but if it is a manual box, with no power steering, and is it's own sump.. you should be fine with a quart of 85/140 int he pointy nose bottle.. 80w90 be fine to.. as well as 75w90.. etc..
heck.. you could probably put utf in there and be fine as far as the gears are concerned.. though the sector seals might weep if they are wore..
soundguy
That is kinda what I thought. Bushings and seal were the only things bad. I had new bushings made and was able to buy a new seal for it. It is just a simple gear box so I'll probably go with the 80-90 I have here. Thanks
   / Ford 1310 Lube Question #4
check the thrust bearings as well.
soundguy
   / Ford 1310 Lube Question #5
My shaft out of the sterering gear box has lots of play in it. Is that what you fixed? If so, how much trouble was it?
   / Ford 1310 Lube Question #6
the sector shaft coming out the side of the box .. if it has slop could be sector backlash.. but that is usually caused by a worn bushing ( some don't have replaceable bushings :( )
soundguy
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2013 Isuzu NPR Eco Max Box Truck (A47384)
2013 Isuzu NPR Eco...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2022 Wacker Neuson SM100 Mini Skid Steer (A52128)
2022 Wacker Neuson...
2014 Dodge Grand Caravan Van (A50324)
2014 Dodge Grand...
