Ford 1300 Transmission Dipstick?
   / Ford 1300 Transmission Dipstick? #1
Ford1300
Hickory, NC
Ford 1300
Hello
I just purchased a 1979 Ford 1300 4x4 diesel tractor. The rubber on the trans dipstick is loose and I have no idea the location it is suppose to be on the stick.
I can't check for the proper oil level.
I was wondering if maybe some one could maybe measure there's from the tip to the base? I have this example picture.
Here is a few shots showing what I mean about the rubber moving.
Thanks.
Tony
   / Ford 1300 Transmission Dipstick? #2
I will measure it for you tomorrow when I go out to the shed and get back to you.
   / Ford 1300 Transmission Dipstick? #3
I just went out and measured my transmission dipstick. It is 8 inches even where you are taking the measurments from. My dipstick is straight all the way up to the finger plll loop. My 1300 is 2 wheel drive. I don't know if 4x4 is any different. Hope this helps.
Ken
Thanks Ken
I will straighten the bend in mine. I didn't think it should be like that.
Surely the 2 wheel drives and the 4x4's would be the same.
Now I know how far from the end it should be and I can file me a reference mark on the stick.
Thanks again for the help.
Tony
   / Ford 1300 Transmission Dipstick? #5
No problem. I have had my 1300 for 11 years. They are a good little tractor.
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
Contender Diamond Plate Toolbox (A51573)
Contender Diamond...
