Ford 1300 tractor problems
   / Ford 1300 tractor problems #1
wannagetrdone
Ok this all started by my brother using ether on it. It has the shibuaru 2cyl diesel engine. The ether use caused the piston to break at the relief points just above the wrist pin. I did an inframe rebuild consisting of pistons rings and rod bearings. I didnt have to mess with the timing or anything else. I got it to fire up and run but it sounds like a midget is beating it with a sledge hammer and when i throttle up its not real smooth. It is firing on both cylinders but has a loud sharp knock. Anyone have any ideas for me.
   / Ford 1300 tractor problems #2
How long did you run it for? I used ether on my Ford/Shibaura and it sounded like what you're describing, but only for a short time then it went away.
Nothing on mine broke, and I see you had yours apart since you used the ether, so I don't really know.
If you didn't see anything else in the top end when you were in there then maybe the lower :( Or maybe something easy like bad injector.
JB.
   / Ford 1300 tractor problems #3
Did you check the rods to see if they were bent from the either. Did you make sure you got the right replacement piston and bearings.
Bill
   / Ford 1300 tractor problems #4
I think I would have had the crank spun and dial indicated as I understand this is a weak point in their power plant. Either can really put some strain on the components. I don't think this noise will go away by itself.... especially if it is a metallic sound. Good luck.
   / Ford 1300 tractor problems #5
I think the likelihood of damage to connecting rod is high if the piston gets damaged as you described. Small damage to the rod may be hard to detect just by visual inspection. Did you change crankshaft friction bearing? There might be some play there after ether explosive force. IMHO use of ether is absoloutley asking for trouble. Were the push rods (four) perfectly straight and undamaged when you put it together?
jc,
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400lb 3 Ton Mechanics Crane Service Truck (A50323)
2013 Ford F-550...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
International 3414 Tractor w/Loader (RUNS) (A50774)
International 3414...
Bush Hog TD1500 (A50120)
Bush Hog TD1500...
1000 Gallon Concrete Fuel Tank (A50774)
1000 Gallon...
