ford 1300 tactor
   / ford 1300 tactor #1
01hunter570
Bronze Member
i just purchased aford 1300 tractor with a loader and backhoe. this little tractor has low hours and i am very happy with it. i didsome research on the net and they all say it is very important to keep watch of the oil in the injection pump. i have the operator manual and it mentions nothing about servicing the injection pump. could someone clue me in on its location and how to change and check the oil in it. i understand it takes the same oil as the engine. appreciate any help, thanks.
   / ford 1300 tactor #2
if its not in the manual then don't worry about it, someone might be pullin your leg.
   / ford 1300 tactor #3
My shop manual includes the 1300 and does not list the 1300 as having the oil drain screws. On my 1700, there are two small screws, one near the bottom and the other halfway up the side of the pump. Change interval is 200 hours for the oil same grade as engine oil). On some of the injector pumps the screw holes were cored but not drilled or tapped.
If you like I can take a photo and circle the screw locations if you like. I provided the information so you can verify if you have the same drain and level screws that are on my injector pump.
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
Coleman 274BH Lantern Edition Travel Trailer (A51694)
Coleman 274BH...
2023 John Deere 6R 155 MFWD Tractor (A53342)
2023 John Deere 6R...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
SHOULE LN-16 LOT NUMBER 132 (A53084)
SHOULE LN-16 LOT...
