Ford 1300 Problem
   / Ford 1300 Problem #1
deano29
abbotsford, bc
ford 1300
Having problems with my older Ford 1300 with overheating. It runs fine on its own but once I try operating my 'Weed Badger' or rototiller it doesn't seem to have enough juice and wants to quit on me. Any ideas of what to look for or check. Already looked over the injectors and changed the filter. Thanks for the help
   / Ford 1300 Problem #2
Check temps on radiator top and bottom tank with infra-red thermometer or equivalent. Normal temp is about 200F on top not sure how much temp drop but bottom tank should be cooler. Check fan belt for tension(1/2 inch deflection). When engine NOT running grab fan and see if it can be rotated easily. Check radiator for obstructions in the air fins and good flow through the radiator
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2018 INTERNATIONAL...
2022 ATLAS XAS188 AIR COMPRESSOR (A52472)
2022 ATLAS XAS188...
2015 HINO BOX TRUCK (A52472)
2015 HINO BOX...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
7046 (A50322)
7046 (A50322)
