63spyder
- Joined
- Oct 7, 2009
- Messages
- 26
- Location
- oregon
- Tractor
- iseki ta250,case vao,case 420b backhoe,agricat tracklayer w/front loader
HI .I have a ford 1300 with a ford front loader.The hydralics slowly went away to the point it will barely pick up the bucket to move the tractor.I went through the search ,checked the filter changed the fluid.Had the pump taken apart at a hydraulic shop.(was told it looked like new).nothing changed.It starts out bad and as it warms up it gets worse.This last time I drained it to check the metal filter again the last of the fluid to drain out was foamy.I checked for air leaks on the intake side and could not find any.I was told that I might have to get a flow meter and check the system that way? Any sugestions would help. Thanks
