Ford 1300 hydraulics return to tank port location
   / Ford 1300 hydraulics return to tank port location #1
chumly2071
Bronze Member
Lexington, IL
Reaching here, as these tractors are now almost 40 years old, so probably not a lot of current owners out there
I've been searching, and looking at the parts diagrams on the New Holland website, but not finding what I am after.
I have a 1300 4x4 with the factory 770 loader (built by SMC/Alamo Group). The original Dukes loader valve is having issues, and I bought a Prince to replace it that has a power beyond port.
The quick version is that I am looking for a port on the transmission housing that I can use for my tank return. The factory valve is open center, and is inline with the original flow path for the 3 point lift (no power beyond). I have adapted a Rhino 60c backhoe to it, and it currently simply goes in series after loader valve, then back in line with the 3 point circuit (when I have the backhoe mounted). I am concerned about the new valve having a rated max of 500 psi on the tank port, and even with the 3 point only, I don't want to risk damaging the new, expensive valve. I'm speculating that this is what damaged my original valve...
SOooooo... I am looking for a "tank" port I can easily tie onto for my tank return line of the new loader valve, and the backhoe valve if/when I reconfigure it to power beyond as well. I guess worst case, I could pull the transmission top cover off and have a couple ports machined into it, but I would like to avoid that if at all possible.
Thanks for your help-
Chad
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
E-Z Trail 680 Head Cart (A50514)
E-Z Trail 680 Head...
20" Sea Container (A47384)
20" Sea Container...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2010 Ford F550 Service Truck (TITLE) (NOT RUNNING) (A50774)
2010 Ford F550...
2013 Ford E350 Box Truck (A47384)
2013 Ford E350 Box...
