Ditto on the crank/ no start question.
if it cranks over fine.. but won't catch next time, loosen the lines at the injectors like you are bleeding it and see if one or more have a little air.
Could be an injector(s) leaking.. or the pump itself leaking on an individual injector line.
in any case.. crak line.. bleed, tighten line.. and see if it fires up fine. if so.. pump may not have been gone thru correctly.. or injectors were not rebuilt good.
Soundguy
