Harbinson
I would like to remove, clean and reinstall the pre-heat chamber on a 1210. How are they removed. They are visible when the injectors are moved and appear to come out through the same opening.
This last snow storm the 1210 failed to start. Probably due to the 30 year old slow cranking starter that finally died. A new one has been ordered and should arrive in a few days (Best price I found - Discount Starter & Alternator | Home).
Now that the tractor is down, I'm trying to fix the cold start problem once and for all: I also removed and cleaned fuel tank, replaced all fuel lines, cleaned the fuel filter canister, installed a new fuel filter, purchased new glow plugs, cleaned the injection lines and had the injectors cleaned and tested by a reputable truck mechanic. My last item is to remove and clean the pre-combustion chambers.
Your thoughts, ideas and help are appreciated.
