Ford 1200 Hydraulic Problem
   / Ford 1200 Hydraulic Problem #1
jimb1
Ruakituri New Zealand
Massey Ferguson 135 4 x 4, Ford 4100 4 x 4, Ford 3000 4 x 4, Ford 1200 4 x 4.
My 1983 Ford 1200 (4 x 4, 2 cylinder model) has a front-end loader and a counterweight on the rear 3-point linkage. With the quadrant control in the locked upper position (continuous pumping), the Hydraulic arms, which used to stay up, now keep dropping. When the bucket control lever is pulled to raise the bucket, first of all the counter-weight has to lift, making the operation quite time consuming.
The only way around this is to have the valve (tap, actually) on the remote outlet that supplies the bucket control spool valves nearly closed, so that the pressure relief valve is "just" starting to open. This puts unnecessary strain on the not-very-powerful engine.
As I said, this problem did not exist before, and I was wondering what component in the hydraulic system is not doing it's job now, and how do I fix it?
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
2022 New Holland T5.120 Tractor with Loader (A51573)
2022 New Holland...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
John Deere 2440 Tractor (A52384)
John Deere 2440...
