Ford 1100 Tie Rods
   / Ford 1100 Tie Rods #1
jrccih
Hodges, SC
Shibaura SL 1703
Hi all, I am brand new here. I have a Ford 1100 4wd, and I have purchased boots for the steering tie rod ends, as the old ones had deterioted. Can anyone help me understand how the cap comes off of the ball fitting? I have taken the castle nut and cotter pin off already, but I don't want to damage the joint. Thanks!
   / Ford 1100 Tie Rods #2
Strike the side of area where the tie rod passes through the spindle with a big hammer. This is the piece the castle nut comes in contact with. I wish I could give you a better discription. Hopefully someone has a pic.
Bill
   / Ford 1100 Tie Rods #3
I believe hooked is tellng you to strike the 'socket' the pin of the tie rods passes thru.
I like to back up the socket on one side with a large hamemr.. then use a couple pound maul on the other side.. 180' off to hit the joint.. this plastically deforms the metal and usually pops the pin up.
other way to do it is to use a pickle fork.. drive the fork betwen the socket and tie rod end.. since you are replacing the boot.. this is the easy way .. it destroys the old boot.. but no biggie.
harber freight has pickle forks for 3.99$..( napa, 20$ ) i bought 2 nearly 10ys ago from HF.. still have both of them.. have done a dozen tractors with them..
soundguy
I appreciate everyones' responses...I may try using a pickle fork as soundguy recommends. I'll let ya'll know how it turns out!
Joe
Update: I managed to hit it correctly and it popped right out, no problem. Thanks everyone for your suggestions here.
Joe
   / Ford 1100 Tie Rods #6
keep us posted , but sounds like you are headed in the right directon.
soundguy
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2013 John Deere 8360R MFWD Tractor (A53342)
2013 John Deere...
FRONTIER CA2072 LOT NUMBER 41 (A53084)
FRONTIER CA2072...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
