Ford 1100 Ignition switch troubles
   / Ford 1100 Ignition switch troubles #1
ronaldg
Ford 1100
My Ford 1100's ignition switch starts tractor, works the cold aid start, but won't turn engine off. I have to pull the the throttle lever beyond the normal stop to stop engine. Any experience with the problem and the repair/solution?
   / Ford 1100 Ignition switch troubles #2
There is no problem with the switch. Your tractor has a mechanical fuel shutoff incorporated in the throttle linkage. The shutdown procedure you are using is correct.
You might want to look into buying an operator's manual so you can read it and better understand how your tractor functions.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A50854)
2013 XLR...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
