Ford 105A rototiller question
   / Ford 105A rototiller question #1
stronics
I have the above rototiller, the shaft that the tiller blades rides is leaking gear oil on the gearbox side. I taken the end off and it has 3 pins or keys in the gear and shaft, can't tell for sure. The gear is loose on the shaft as you can see slight movement when rocking it back and forth but won't come (slide off). What am I missing? Anyone had one apart?
I can't find a manual for it anywhere yet.
Thanks for any information,
David
2013 Hyundai Sonata (A50324)
2013 Hyundai...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
