Ford 1000
   / Ford 1000 #1
TBAILEY
Does anyone have any info on ford 1000 diesel made in japan
filter, fluid capacities, weight of oil etc.
   / Ford 1000 #2
Yes, I have the same tractor. It's a 25 hp/24pto. I'll have to dig up my owner's manuel to get you the rest.
   / Ford 1000 #4
TBAILEY:
I had a Ford 1100 4WD for 20+ years. According to my manuals it was 13HP/11PTO HP. It was a small and manuverable little tank and was able to do everything I demanded of it. It could handle hills better than my NH TC29DA and brush hogged 7+ A's of a rough and overgrown sloped obstacle course without problem with a 40" rotary mower (It took awhile.). It's 42" Woods tiller handled NE packed clay/stone better than the tiller ultimately did. Fuel Tank = 3.7G, Cooling System = 3.2G, Engine Crankcase = 3Qts/3.2 with filter change, Rear Axle/Transmission = 20Qts, Front Axle Differential Case = 1.6Qts, Front Axle Final Reduction Gear Case = 0.21Qts, Oil = 10W CD < 32 degrees F, 20W CD 32 - 50 degrees F, 30W CD > 50 degrees F. I wish "She Who Must Be Obeyed" would have let me keep it when I "upgraded" :( If you need anymore information let us know. It is a solid little tractor :) :D Jay
   / Ford 1000 #5
My Ford 1100 is on it's way out also, after having owned it for about the same 20 years. Been a GREAT little tractor, doing things that only a fool would ask a tractor twice that size to do.
Hope you have half the luck with it that I have had.
David from jax
   / Ford 1000 #6
sandman2234 said:
Funny, I have an 1100 4x4 (that is fixing to be sold) and it is only 13Hp. Would have figured a 1000 to be a similar tractor.
David from jax
I think you may find that there are 2 different 1000's in Fords past. One was the predessor of the 1100 and the other a higher hp unit from the 1000,2000,3000... series.
Andy
   / Ford 1000 #7
Figured I would be wrong on that ASSumption.
David from jax
   / Ford 1000 #8
the 1000 ford in the 1000,2000,3000 series was built in japan by shim.... something, is a 23 horsepower tractor, and holds 5.3 quarts of oil with a filter change and uses a napa 1512 filter. my dad is in the process of rebuilding ours because it cracked a piston and i need to know how tight to torque everything. i haven't seen much information on this tractor anywhere. hope this helps...
   / Ford 1000 #9
The 1000 tractor was a 2 cyl built from 73 to 78. Shibaru was the manufacturer.
the 2000/3000 3 cyl model was a ford built 3 cyl from 65-75.
there was an early 2000 4 cyl ford built from 63-64 that was basiaclly a 601 model.
The 1000 was not really related in any way to the 2000/3000.
soundguy
Kubota L35 Backhoe Loader (A42742)
Kubota L35 Backhoe...
Club Car Electric Utility Cart (A42744)
Club Car Electric...
2025 Kivel 48in Skid Steer Forks and Frame (A44571)
2025 Kivel 48in...
2001 Dodge Ram 2500 Pickup Truck Extended Cab (A44789)
2001 Dodge Ram...
1980 LINKBELT LS-318 LATTICE BOOM DRAGLINE CRAWLER (A45046)
1980 LINKBELT...
Sea-Doo Switch Sport 18ft Pontoon Boat with Boat Trailer (A42744)
Sea-Doo Switch...
