For you snow plow owners...
   / For you snow plow owners... #1
frischtr
Harford County, MD
PT-425
Here is a cheap alternative to the rubber lip kit for the PT snow blade. I couldn't justify the expense of the PT kit when I purchased in the spring, but I needed something to protect my blacktop during the coming winter.
All you need is an old tire and some bolts/nuts/washers. I'm sure this has been done before, but I didn't search for it...
Enjoy!
How did you cut the tire? I have never had any luck.
A sawzall with a demolition blade (just a heavy guage metal cutting blade), and the wife helping to hold the tire steady. The porta-band in the first picture cuts better, but the throat isn't deep enough to cut the sidewalls off, only good for cutting the tire to length.
   / For you snow plow owners... #4
Sorry. Does not work for me at all. Tried it and the blade was toast in minutes. Must have bought cheap blades or had the wrong kind of tires (they were truck tires)
   / For you snow plow owners... #5
I don't know if you realize how stiff and sturdy the Power Trac rubber blade edge is. It is slit and cut rubber coal belts. It has stiff rubber and Kevlar in it. Tires are lucky to have some type of string in them but you have the steel belts to deal with. When mine wears I will flip it over and use the other side and then will finally replace it with another rubber coal belt either from Power Trac or somehow get one and make it myself.
   / For you snow plow owners... #6
If you want heavy duty rubber, try a gravel pit. Most of the quarries around here give away the older belting for free. YMMV
All the best,
Peter
   / For you snow plow owners... #7
Some have used stall mats from TSC. A 4 ft by 6 ft. mat for less than $40. I don't know how well they have worked..
   / For you snow plow owners... #8
I've used them for other uses, and I would just observe that they tear reasonably easily. I think it might not make the best material, but the proof is in the pudding for use on a blade.
All the best,
Peter
   / For you snow plow owners... #9
If I remember correctly, wet rubber is easier to cut. Maybe a carbide blade, or shear.
   / For you snow plow owners... #10
I have used the stall mats for over 5 years without any problems. I used a sawsall to cut
(not easy to get straight) and bolted on.
PJ
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
2004 MANAC 48FT CURTAIN SIDE SPREAD AXLE TRAILER (A57880)
2004 MANAC 48FT...
2008 International Bucket Truck (A55973)
2008 International...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
