For those who want to try 50 hour service...
   / For those who want to try 50 hour service... #1
Typhoon
Southern Illinois
LS MT357HC
For those of you who want to try the 50 hour service yourself, I just did mine on my DK40SE and it was a breeze. I was a little nervous about doing it, but I went to my dealer, and the service guys went over a few things with me, and it was much easier than I anticipated. FWIW, they told me to run the same fluid in my front differential and in the HST/Hydraulic system. The only snag that I hit, was the hydraulic filter (not the HST filter). It was a little too big for my filter wrench (band type). So I ended up having to punch through it with a big screwdriver to get it off. Other than that, no problems at all. I didnt use any fancy pumps to put the fluid back in either.. I just used a long funnel. Also, after topping off the front differential, I had to drive the tractor for a bit, then refill again, drive again, refill again, etc. It takes some time to get all of the fluid to settle in the differential. Good luck!
   / For those who want to try 50 hour service... #2
Good job. I believe that your manual calls for either UTF or gear oil in that front diff. People do different things and Kioti used UTF on mine from the factory. I look into the axle and I see gears so I put gear oil in there.
Those filters can be extremely tight and painted on from the factory.
Keep checking that front diff level. Many folks have underfilled it.
2020 KENWORTH T680 SLEEPER TRUCK (A52141)
2020 KENWORTH T680...
2019 Bobcat E26 (A50120)
2019 Bobcat E26...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
Kent KHB3G Q.A Hydraulic Breaker (A50121)
Kent KHB3G Q.A...
