For those that have made PTO sprayers
   / For those that have made PTO sprayers #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
Seeking a filter to go between the PTO pump and the tank on the suction side, used primarily to protect the pump. Can anyone that has made a spray rig in the past make recommendations here please.
   / For those that have made PTO sprayers #2
Tractor Supply stocks the suction line filters for sprayers. They usually come with 1/2", 5/8", 3/4" etc inlet and outlet. They trap small particles and prevent the noozles from becoming clogged. Stopping every few minutes and cleaning noozles is no fun when spraying. Also the fluid sprayed could be very toxic.
   / For those that have made PTO sprayers #3
Hi PineRidge,
Agri Supply also has them. On my sprayer, a ball valve is screwed into the bottom of the tank and the filter is connected to the valve. I found that when cleaning up the rig after spraying, it is convenient to remove the filter "cup" to allow the water to drain faster from the tank. While I have it off, I can check for debris in the screen and flush it out if needed. The filter mesh screens come in various sizes, and I am not sure what to advise you on that one. The screen is finer than window screen.
HTH
-Vinnie
Thanks for the info and advice guys.
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
Ford Pickup NR (A50323)
Ford Pickup NR...
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
Tri-Axle Police Bunk Travel Trailer (A51694)
Tri-Axle Police...
