Z-Michigan
Veteran Member
For anyone curious, here is my gas mileage for the first 5400 miles of driving a 2007 Suburban 1500 4x4 with the standard 5.3L gas engine (with AFM and E85 capability). This driving is about 70% commuting (mix of highway and city) and 30% pure highway/freeway travel. I have not done any towing or heavy hauling. There are no mods, but I did switch to synthetic engine oil (Pennzoil Platinum) at 1600 miles. These are all hard numbers from the odometer and gas receipts, no trip computer iffy numbers or optimism. % ethanol in the fuel is a guess except when I've bought E85 or when indicated on the pump. The overall average so far is 16.94, compared to EPA numbers of 15/20 (old system) or 14/19 (new system).
The AFM feature (v4 mode) comes on all the time on the freeway when on the slightest downhill or sometimes even on pure flat ground, even at over 70mph, and fairly often in highway cruising. I doubt a non-AFM motor would get nearly as good mileage in this driving.
I am running 34-35psi cold pressure in the tires, which is above the minimum of 30psi but well below the tire ratings for max pressure and leaves me with a good ride and no apparent tire wear issues.
The tank of 19.9mpg was a mix of highway and freeway driving in Indiana in fairly mild weather, but at normal speeds and including some hills (Brown County). I think 60-65mph is a sweet spot for getting best mpg in this vehicle. I have noticed that mileage is terrible when cold, and being able to drive 200+ miles at a stretch without the engine cooling off probably helped the mpg.
The last four tanks were on 89 octane midgrade, which I'm experimenting with to see if it improves mpg - it would seem to, but all four tanks were mostly freeway driving so I don't yet have a large enough sample to be sure (though most of those four tanks also saw a lot of 4wd use in snowstorms, which just muddies things further).
Odometer Reading Gallons Purchased Date Trip Mileage Trip MPG Fuel % Ethanol This Fill % Ethanol in Tank 3-Tank Average
282 0 10/11/07 n/a n/a gasoline 5 5.0%
475 10.934 10/15/07 193 17.7 gasoline 5 5.0%
858 22.542 10/19/07 383 17.0 gasoline 5 5.0%
1232 22.226 10/25/07 374 16.8 gasoline 5 5.0% 17.06
1396 9.962 10/30/07 164 16.5 E85 85 30.7% 16.83
1812 25.469 11/04/07 416 16.3 gasoline 5 9.6% 16.55
2189 21.2 11/07/07 377 17.8 gasoline 10 9.9% 16.90
2480 14.627 11/08/07 291 19.9 gasoline 10 9.9% 17.68
2819 20.256 11/16/07 339 16.7 gasoline 5 6.7% 17.96
3015 12.27 11/21/07 196 16.0 gasoline 10 8.0% 17.52
3272 15.164 11/24/07 257 16.9 gasoline 5 6.5% 16.61
3487 13.136 12/05/07 215 16.4 E70 70 33.4% 16.47
3791 19.097 12/11/07 304 15.9 gasoline 5 15.9% 16.37
4029 14.552 12/16/07 238 16.4 gasoline 5 10.8% 16.18
4379 21.943 12/23/07 350 16.0 gasoline 10 10.2% 16.05
4569 10.759 12/24/07 190 17.7 gasoline 10 10.2% 16.46
4819 13.71 12/27/07 250 18.2 gasoline 5 7.9% 17.02
5183 20.764 12/30/07 364 17.5 gasoline 5 5.9% 17.77
5457 15.821 01/02/08 274 17.3 gasoline 5 5.5% 17.66
