for 951 48" rotary cutter
   / for 951 48" rotary cutter #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
for 951 48\" rotary cutter
Hello, I have just come across a ford 951 48" rotary cutter that I'm preping to cut with. I've done the usual, inspected the blades, greased the pto shaft and joints, and was wondering what to put in the ger box to top it off. The manual ( from 1985 ) says to use the following:
sunoco 850 aep, or gulf mining lub HD, or mobile ep023
I can't seem to find these.. anyone know what they spec out to or are equivalent to?
Thanks,
Soundguy
   / for 951 48" rotary cutter #2
Re: for 951 48\" rotary cutter
I sure don't know about those names, but I can't recall any gearboxes on rotary cutters that don't use 85W-90 gear oil (and some people use the 85W-140 instead). Is there any oil in it so you could look at some of it and see what it "appears" to be?
It is nearly full, and just requires topping off, and really looks like it is a rear end lube like you mentioned.. like 85/140... smells like it too.
I soppose it wont hurt anything to add some more rear end lube to top it off.
Soundguy
2019 Ford F-250 XL (A50120)
2019 Ford F-250 XL...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2020 Chevrolet Tahoe SUV (A50324)
2020 Chevrolet...
