footing for post
   / footing for post #1
JimMorrissey
Veteran Member
Southern Maine (now)
'05/'06 L39 TLB
Haven't been on for a bit.....
I'm helping a friend add a couple of support posts to a main beam in his basement. His living room floor is bouncy and he wants to firm it up. Problem is the slab is pretty thin, so I'm going to cut a square in the slab, dig out the dirt and fill it flush with concrete to strengthen the area for the posts. I'm thinking 12"x12" about 6" deep should do it. Anybody have any spicific parameters for depth and size of the footing?
   / footing for post #2
Your formula is correct, double the width as to the depth. I would go 18" square and a 9" thick pour. Don't forget to tamp the bottom of the hole and to wet the ground around the inside of the hole and the surrounding concrete. You don't want the footing to dry out too quickly. After it is poured, cover with a piece of plastic to slow the drying and to improve the cure strength.
Dusty
   / footing for post #3
I like the idea of the footing being allot deeper. You're probably alright at 6 inches, but if it was me, I'd go down at least a foot. It's such a small pour that it won't cost very much more to double it.
Eddie
   / footing for post #4
Instead of wetting the dirt down inside the hole you could also put plastic along the edges of the hole in the dirt
   / footing for post #5
I recommend you look at the whole structure. Get some idea of how much floor area and roof area might bear on this new footing. That is the determinate of the footing size. The suggusted 18" square is 2.25 square feet and if your soil can bear 3000 lbs per sq. ft. then you can carry 6750 lbs on that footing. A matrix of rebar may also be a good idea.
It could also be very likely that the existing structure is already carrying the loads adequately, so your new footing is unlikely to ever fail.
Good Luck,
Jim
   / footing for post #6
My last experience similar to yours was approved by inspector in a crawl space, two or three concrete blocks on a 24x24x8 pad used to support the middle of an i-beam on a 20' wide addition
   / footing for post
Thanks. I think I'll just go big with 18x18x9 pads so I won't have to question it....maybe throw some rebar in for good luck and go with fiber reinforced concrete. Material costs won't be too much and the base is sand so it'll be easy digging with high bearing.
   / footing for post #8
Are you going to use one of those screw jack type adjustable columns so that you can tighten it up just right? I think those are super.
   / footing for post #9
you might consider the prefabracated plastic footing forms.
most of the math has been worked out for you. set it flush with the basement floor and id say your covered... the website even has calculators to help you figure the right size based on load.
Square Footing Form Do It Yourself Information
   / footing for post #10
I'd go 24x24x at least 12" you only want to do it once. Rebar and the works. But a lot depends on your soil. I watched a foundation company work once. When the hydraulic jack, they were pushing 8" round peers (flat on the bottom) into the ground like it was nothing. The guys says he watches the pressure gauge on the lift to let him know when he hit the solid clay. 2000-2500psi or somewhere in that area. Some places in this house got 3' down, some got as much as 5' down. Much deeper then the bell bottom peers that had previously been put in a failed.
It was neat to watch.
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
2016 VOLVO VNL SLEEPER (A54313)
2016 VOLVO VNL...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2015 Ford F-550 Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
2009 Ford F-550 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2009 Ford F-550...
