Foot wear
   / Foot wear #1
wedge40
Veteran Member
What foot wear do people have on when doing tractor work?
I have a nice pair of steel toe work boots, but sometimes I'm lazy and just run out there with tennise shoes.
Wedge
   / Foot wear #2
scandals? sneakers? boots? all of above!:D I guess it depends what I am doing.
   / Foot wear #3
I wear Irish Setter Soft Paws EVERYWHERE. Most of my "tractor work" is in a cab.
When I was younger and did more real work, I wore heavy work boots.
   / Foot wear #4
Well for this time of the year I usually jump in my knee high insulated Cabala's rubber boots because they are high and warm and water proof. The snow on the ground here is about 24" now so I can walk anywhere without having snow dump into boots.
DevilDog
   / Foot wear #5
Whatever you wear, make sure it's got decent tread. My tractor is a gear (not HST) and a few times I've tried to depress the clutch to stop the tractor and my foot slip off the clutch pedal. Obviously, if this happened at the wrong time, serious injury could occur. This most often happens when the ground is wet and the sole of my shoe is wet as well. I've thought about welding some sort of bar or cleat on the outside edge of my clutch to prevent this.
Has anyone else had this problem?
   / Foot wear
Yes this has happened to me when I was wearing my tennise shoes, but never with my work boots that have heavy cleated soul. I also have a clutch to deal with, so after having my foot slip off the clutch, I'm more diligent about wearing my work boots.
Wedge
   / Foot wear #7
Whatever I happen to have on when I need to get something done. Boots, tennis shoes, even no shoes every once in a while. Not something I would advise, just what I do. Not sure how my foot would slip off the clutch, the only time I’ve even been close was with a lot of mud on my boots. In the summer I bet I wear tennis shoes 50% of the time. If I miss the clutch it’s usually my fault.
   / Foot wear #8
I use sneakers. I find it is very difficult to use the pedals with my work boots.
   / Foot wear #10
i used to wear work or cowboy boots no matter what i was doing.but as my feet got bad i can no longer wear them.so now im in tennis shoes or rubber boots no matter what the job is.
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2015 New Holland Boomer 47 4WD Agricultural Utility Tractor (A53421)
2015 New Holland...
Harrell 3605 (A50123)
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
2017 TROXELL 150BBL ALUMINUM TANKER (A53843)
2017 TROXELL...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
