Rotary Cutter Folding Deck Rotary Cutter
   / Folding Deck Rotary Cutter #1
Turkeyman
Columbia, SC
JD 4720 and 5075M
Does anyone have or use a folding deck rotary mower (a/k/a tree cutter)?
I saw a power line clearing crew with a Brown 6' model, that with extra steel was $6000, but would handle a 8" hardwood tree.
   / Folding Deck Rotary Cutter #2
<font color="blue"> I saw a power line clearing crew with a Brown 6' model, that with extra steel was $6000, but would handle a 8" hardwood tree. </font>
Can' help but want to see the tractor that was pulling the cutter that would shread up a 8" hardwood tree...
Around here an 8" tree would take a bit of effort to push over...especially if several were clumped together...
   / Folding Deck Rotary Cutter #3
The blades cut through like an axe would.
Two of them were older NH 8610? and a newer TS 90 with enclosed cab, 4 wd, with duel R1 on rear, skid plates that were 3/8 thick and full roll cages and screens. Around the push bar was wraps of 5/8 cable to pull each other out. Also had a Hydro-Axe, which looks like a wheel loader but has a 9 ft rotary cutter in place of the bucket ( 12 " capacity) and a winch that is rated for 75,000 lb on the rear. The mower can be put 10 feet in the air. The mechanic said they order extra strong ( Rockwell #) blades for them.
More time is lapsing between cuttings so they need extra HD, equipment to handle 60-70 hrs a week in summer.
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
Parker 250 bu Gravity Wagon / Seed Tender (A50515)
Parker 250 bu...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
