Foldable ROPS problem
/ Foldable ROPS problem #1
gusg
Vail, AZ
B7510 with R4s
Just got my 7510HSD today and I have a ROPS problem. I had a hard time getting the bolts out to fold it down. The left one goes back in easy but the right one appears to be stripped and I can only get it in about 3/4 of the way. I can't tell what condition the nut is in. Has anyone had this problem? It looks like it is easy to get a new bolt from the dealer and install it myself. Hopefully the nut is O.K.
The second part of my question is has anyone traded a foldable ROPS for a fixed ROPS after delivery? I heard it is quite a job to change (I would think that only the top part needs to be changed (4 bolts). One dealer told a poster in an earlier thread that the Serial Numbers of the tractor and ROPS are matched and submitted to Kubota so it is too late to switch. I didn't think that a fixed ROPS would fit in the garage but at a height of 75.5 inches a fixed will fit. The foldable ROPS is about 2" too tall to get into the garage without folding it. It is a pain to put it down and take it up everytime I take it out of the garage and I do not intend on getting a BH. It appeared that the dealer only sold his tractors with foldable ROPS.
Did about an hour of dirt moving today. Love this tractor as much as I did my 7500. In fact Kubota has changed most of what I had a problem with on my 7500.
/ Foldable ROPS problem #2
If the bolt won't go into the nut it could be a thread issue -or- more likely an alignment problem. Often the nuts are welded just a little off the hole centerlines or angled slightly. That puts the bolt on a bind to the nut. If that's your problem and it's threading in 3/4" (and not destroying the threads) it's nearly in align. Mine was binding in a very similiar description to your's when new. I put some spray lube on and each time it worked in a little more. It's fine now. I'm certain a little metal was lost from a few surfaces and threads but nothing visible.
If your tearing up or stripping the threads as you suspect, you have a more pronounced alignment issue.... which needs the dealers attention. Either way, it shouldn't be a big deal to correct.
HTH
/ Foldable ROPS problem #3
There is only one "sweet spot" where the bolts will go into my foldable ROPS by hand. I use one hand to wiggle the ROPS around til I find it and the other to run the bolts in. I can't see how you could strip the threads on either the bolts or nuts with no more torque than is available "by hand". If you have to use a wrench or pliers, things are out of alignment.
Jeff
2005 Katolight VSD60FGJ4 60kW Standby Diesel Generator (A61572)
2005 Katolight...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A63569)
2008 PROGRESSIVE...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
